Jason & Ed:
Not sure if this helps but I use this work-a-round. If the right of way is
consistent, I will off set it, use the Parcel command to define it, then use
the Parcel entity delete key to remove the parts that I don't want. This
includes making a new radius by using the fillet command with the new RW
lines before I "Parcelize" it.
Bill
"Jason Hickey" wrote in message
news:5175786@discussion.autodesk.com...
Ed Canvasser wrote:
> May be covered already, but I searched and didn't find anything so sorry
if
> this is old. After an arc has been converted to a Parcel object segment
and
> now want to adjust the arc's mid point, but no grip to select. We have a
> situation where the street needs to be widened and short of erasing the
arc
> and rebuilding can't figure it out.
> Any ideas?
Ed,
Once you convert it to a parcel, it can't be edited. To get it back to
an editable state, you have to explode it - not good, in my opinion.
That takes away the major functionality (the "dynamicness") of parcels.
Jason Hickey
Civil 3D 2007
Dell Inspiron 9100
3.0 gHz, 2 GIG RAM, ATI Mobility Radeon 9700 (128 MB)
Windows XP Pro SP2
http://beneaththelines.blogspot.com
