Civil 3D Forum
No menus defined
2 REPLIES 2
greetmendonck
695 Views, 2 Replies
No menus defined
Hey,
I have had lots of trouble when i wanted to install autocad civil 3D on my laptop.
Now, after several hours of install and uninstall and reinstall...i have a version installed but my menus are missing.
Problem is that i have no menus at all. And when I want to do CUILOAD ...I only find menus from a basic autocad (no civil)
so problem is that i have now a civil 3D version where i can only make a drafting version visible.
Can somebody please help me?
Thanks in advance!
2 REPLIES 2
rkmcswain
in reply to: greetmendonck
1. Did you perhaps install under one account (such as local admin), and then try to run it under another account? There is a known issue where exactly what you describe occurs.
2. Take a look in this directory. This is where C3D.CUIX should be:
%appdata%\Autodesk\C3D 2015\enu\support
greetmendonck
in reply to: rkmcswain
Thanks a lot for your answer!!
I did install it under the administrator logon. Indeed, that was the problem.
So..... I found that C3D.CUI file and now i have the correct civil 3D menu bars.
Finally....i can work again! Smiley Very Happy
greetzz!
Rail Community
