When I drag text away from my point there is no leader. I have gone thru everything I can think of in Label and Point styles. I know its probably a simple fix. Somewhere down the rabbit hole is a box that needs/or not a check. Help please. Frustrated here.
Solved by troma. Go to Solution.
One quick thought: if you are zoomed in too far it might look like you're dragging a good distance, but it might not be enough?
Mark Green
Working on Civil 3D in Canada
