Civil 3D Forum
No Layers Toolbar in 2015 - what's my Layer?
15 REPLIES 15
Message 1 of 16
neilyj666
2788 Views, 15 Replies
Civil 3D 2015 seems to have binned the Layers toolbars which were useful for seeing the current layer, freezing thawing etc etc - without having to go to the Home panel. Is there any alternative now - I've added some Layer icons to the QAT but this is getting very cluttered?
and how do I get the LayerFilterComboControl onto the QAT
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
15 REPLIES 15
Message 2 of 16
jmayo-EE
in reply to: neilyj666
IF you go to the home tab of the ribbon, layer tools panel and right click on the dropdown layer list you can select Add to Quick Access Toolbar. This will place the dropdown on top of the screen. There is new function to this as well. You can now assign layer colors from this drodown where the older dropdown for the older toolbars does not permit this.
John Mayo
Message 3 of 16
jmayo-EE
in reply to: jmayo-EE
Do the same with all of your favorite layer commands I see in your image and you can get a little screen real estate back from the old toolbars.
John Mayo
Message 4 of 16
neilyj666
Thanks John - I'll play around with the QAT to see what I can get
Message 5 of 16
jmayo-EE
No problem Neil. Here's a sho of my QAT. Remove what you don't use add what you need all with a right click. It's nice to have these commonly used commands never leaving your site with workspace and ribbon changes.
John Mayo
Message 6 of 16
wfberry
neilyj:
I believe the layer toolbars are the same as 2014.  Try LAYERS II from the Autocad Toolbar selection.
Bill
Message 7 of 16
neilyj666
in reply to: wfberry
Not sure the LAYERS II is available anymore in 2015?
Message 8 of 16
wfberry
They are installed on mine.
Bill
Message 9 of 16
neilyj666
How do you access them?
Message 10 of 16
wfberry
In my case, I right click on either the left or the right border and I have about 6 options to choose from.  One of them is regular Autocad.  Now if I remember correctly they did not want to show up until I have at least one Autocad toolbar on my screen after which all the toolbars are available.  I wish I could remember how I got it started.  I just remember it usually takes me some time to get it.  If Jeff is available I am sure he can tell you real quick.
Bill
Message 11 of 16
neilyj666
Thanks - I'm just uninstalling the whole IDSP 2015 (for other reasons) and will try it when reinstalled although quite like jmayo's QAT suggestion
Message 12 of 16
jmayo-EE
I believe the key to displaying the available toolbars is making sure you right click on a blank area right next to any docked toolbar.
John Mayo
Message 13 of 16
Jeff_M
Right-click the area where the Transparent commands toolbar is located. If you have no toolbars displayed, edit the CUI, modify the workspace, scroll to the PArtial Customization files, choose Autocad, expand Toolbars, scroll down to LayersII, check the checkbox.
Jeff_M, also a frequent Swamper
Message 14 of 16
neilyj666
in reply to: Jeff_M
Thanks Jeff
Message 15 of 16
neilyj666
Got the toolbars back now although still may go with the QAT solution
Message 16 of 16
tmullins
In 2014 on the View ribbon tab, User Interface all the way to the right, there is a Toolbars button that will list the available toolbars. They finally added that in 2012 or so (?) because it was a real killer trying to find the right open space to right-click in. Or worse yet having to edit the CUI just to get one to show.
Rail Community
