I have created a surface, when I hover over a contour on it I used to get name,style, layer, elevation. Now I get them all except elevation, I didn't change anything (not on purpose at least) in my drawings does any one know of a reason for this?
Solved by troma. Go to Solution.
Open the Properties dialog for your surface and check that the Tooltip option is turned on.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Open the Civil 3D surface properties dialogue (not the Autocad Properties pallete). On the lower left corner of the Information tab there is a toggle Show Tool tips. Make sure that is on.
If it is then you'll need to check your global settings for the file and for your Civil 3D user profile or workspace.
Mark Green
Working on Civil 3D in Canada
Thanks, I have been looking up how to turn those elevation hovers off since I so many surfaces loaded it was slowing things down
In addition the the settings mentioned in other comments, I also had to DRAWORDER my surface to the front.
Ah yes, the beauty of the NCS template. No layer control for your surface (try IsolateLayer) but you still need to manage two layers. Even more when you add labels. Twice the work for half the function!
He facetiously said...
John Mayo
