Hi all,
it seems there is again problem listing auxiliary points in auxiliary list in SAC 2015. Please see attached example...
Martin
if use sac2014, you dont have any proplem.
help say: "The point may be either a Point or an Auxiliary Point" but it is not at work.
things getting worse, many sac2014 files does not work on sac2015.
maybe you need to install a patch or might be good a sp.
bu arada You can find a solution for about to convert 3D drawing to 2D ?
