I am fairly new with autodesk and well I have an issue.
I recieved a drawing from a co-worker and opened it using c3d 2012, a window appears with the following text: This drawing contains newer versions of objests. to work with the newer objects in a limited fashion, enable proxy graphics and then rename the drawing in the current version. you can also export the drawing to autocad: however, be aware this permanetly converts the AEC objects to basic autocad objects.
I only have one option to close the window, and another shows up with the following: This drawing was created with a newer version of civil3d. all entities created by civil 3d within the drawing are in a proxy state. Additionally, all commands, settings, and displays of civil3d are disabled for this drawing.
Any insight would be much appreciated.
Solved by Jay_B. Go to Solution.
Open the drawing and type 'OPTIONS' _tab OPEN AND SAVE and choose 'show proxy graphics'.
Ask to your co-worker to export the drawing to autocad.
ok, So the file is a dwg from autocad....is there anyways to import it to civ3d 2012 and build a surface, pull points off and create a tin file?
Is there a way to find out what program and version was used to create the .dwg file?
Open the drawing file with Notepad. First line in file will have AC1027 for Release 13 products:
AC1027 AutoCAD 2013
AC1024 AutoCAD 2010,2011,2012
AC1021 AutoCAD 2007, 2008, 2009
AC1018 AutoCAD 2004, 2005, 2006
AC1015 AutoCAD 2000, 2000i, 2002
AC1014 AutoCAD Release 14
AC1013 AutoCAD Release 13
AC1009 AutoCAD Release 11, 12
AC1006 AutoCAD Release 10
AC1004 AutoCAD Release 9
AC1003 AutoCAD 2.6
AC1002 AutoCAD 2.5
Bill
