Civil 3D Forum
New UCS does not display
4 REPLIES 4
jacobekola
683 Views, 4 Replies
I have just started using 2011 and I am having trouble creating new Named Views.  After I have rotated a drawing and set the UCS xy with the screen, I do not get a new USC to rename.
The steps I use are.
1.  I use DVIEW to rotate a drawing.
2.  VIEW to set the UCS xy with the screen
3.  UCSMAN to name the new UCS.
4.  NAMED VIEW to create and store the new view.
These are the steps I used in 2010 and they worked fine.  In 2011 When I get to step 3 the is no "unnamed" UCS to rename.  I have installed update 1, I didn't try rotating views before installing update 1.
Jacob
4 REPLIES 4
omc-usnr
in reply to: jacobekola
UCSICON "on"?
jacobekola
in reply to: omc-usnr
UCSICON is set to on and it still doesn"t work.
jmayo-EE
Can you save the UCS from the command line using the S switch?
John Mayo
jacobekola
in reply to: jmayo-EE
I'm not exactly sure what you mean.
I can save the UCS, but when I use the UCSMAN command there should be a UCS titled "unnamed" which I would then rename to describe the UCS.
Rail Community
