I have just started using 2011 and I am having trouble creating new Named Views. After I have rotated a drawing and set the UCS xy with the screen, I do not get a new USC to rename.
The steps I use are.
1. I use DVIEW to rotate a drawing.
2. VIEW to set the UCS xy with the screen
3. UCSMAN to name the new UCS.
4. NAMED VIEW to create and store the new view.
These are the steps I used in 2010 and they worked fine. In 2011 When I get to step 3 the is no "unnamed" UCS to rename. I have installed update 1, I didn't try rotating views before installing update 1.
Jacob
Can you save the UCS from the command line using the S switch?
John Mayo
I'm not exactly sure what you mean.
I can save the UCS, but when I use the UCSMAN command there should be a UCS titled "unnamed" which I would then rename to describe the UCS.
