I am new to Civil 3D. Looking to upgrade from Carlson. Anyway i am going through "Mastering Civil 3D" and have gotten to this point...I have created a corridor with different regions for 2 - 3 lane transition. My cross sections look fine so everything looks good so far. I go to create a surface, select links, top, and create boundary. Hit "OK" and everyhting seems to have processed. The only problem is that nothing was created. The surface file contains no data
and no contours. How can the corridor sections appear correctly but no surface can be created? I'm sure it is something simple that i am leavign out but I have gotten frustrated. A little help please!
A couple of screen shots might help. For example: the dialog box where you're creating the surface.
@Anonymous wrote:...
Well, there you are sectioning the corridor itself, not the corridor surface.
Mark Green
Working on Civil 3D in Canada
Is the surface style "Contours 2..." set to display?
Are the necessary layers on?
Mark Green
