Distinguished Contributor
taneum
Message 11 of 14 (368 Views)
Re: New pressure pipe parts not working
08-28-2012 08:25 AM in reply to: JoeHess
I just took it out and it works for me as well.  Thaks!
ptn
Member
ptn
Message 12 of 14 (367 Views)
08-28-2012 08:29 AM in reply to: JoeHess
That was the trick! It kind of makes sense to me now, knowing it uses a SQLite daabase and trying to use quotes in a field. Thanks a bunch, this problem was driving me nuts!
Active Member
pietraca
Message 13 of 14 (111 Views)
03-14-2014 04:16 AM in reply to: ptn
Quick Update on this . In 2914 as you might guess its still the case. Removing the quotes fixes.  Wasted a few hours tracking this down.
Active Contributor
rjairath
Message 14 of 14 (35 Views)
08-05-2014 05:53 AM in reply to: pietraca
good thing i found this ..I made a whole catalog 3 months ago.. justa dded 3 new parts and I could not figure just why they would not work.. until I read about the " (inch mark) low behold my 3 new items had inch mark under the nominal description changed it (in) and now it works.
Autodesk should add a notation stating what charaters should not be used in fields in their Part Publishing guide book.
ps: under what category does the community save flanges and gaskets?
odd that a pressure catalog does not have flanges
Thank you for reading,
Win7 64bit Pro
Xeon E5-1620 v2, 3.70GHz, 32GB Ram
Please mark solution found if this post solved your issue or give kudos when appropriate.
