Just yesterday for the first time I inserted two 328MB GeoTIFFs in Civil
3D 2010 SP2 with Windows 7 Pro 64-bit using MAPIINSERT. The loading
time was much faster than with Vistax64. I was able to pan and zoom
almost like the images were just regular line work. That never happened
before. This is the exact same machine as I was running before, just
that I wiped the drive and did a clean install of Windows 7.
Your decrease in performance in 2010 coming from 2008 is mostly due to
.NET. For some reason Autodesk is obsessed with the ribbon and .NET.
That's the main reason we had to put more RAM in everyone's computers.
It's also the reason that I'm the test bed for a 64-bit OS. I'm the
only one out of 300+ computers on our network that is 64-bit, including
servers. So far so good, though.
EB
Win7 Pro 64-bit
Civil 3D 2010 SP2
4GB RAM
On 11/10/2009 7:04 PM, bdaly wrote:
> After upgrading to C3D 2010 from C3D 2008, our users noticed a decrease in system performance. We generally expect new software to be more demanding of the hardware, so this was no big surprise. While they like the new features and interface in C3D 2010, they aren't satisfied with the performance. We are looking for ways to improve that performance in a cost effective manner, whether that requires upgrading the O/S, upgrading components, or buying new machines.
> To get an idea of the kind of performance difference to expect between Windows XP Professional x64 and Windows 7 Enterprise x64, we ran the latest "Cadalyst Systems Benchmark 2008 v5.2" (http://www.cadalyst.com/benchmark-test) dated August 2009 on the same 3-year old Dell Precision 390 (4GB RAM, Quadro FX 3450, 2.13GHz Intel Core 2 Duo).
> We formatted the hard drive and did a fresh installation of the O/S each time, downloaded all available Windows updates, installed the most recent AutoCAD certified/recommended driver versions based on http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7107053&linkID=9240618. For Windows 7 x64, we used the driver version recommended for Vista 64 since Windows 7 isn't listed. We also did a full disk defrag after everything was installed. We used C3D 2010, the 32-bit version that can be installed on a 64-bit O/S.
> This is the exact same computer, reinstalled twice, with the only difference being the O/S. Except for the necessary system drivers (motherboard, NIC, etc.) and defrag software (Windows defrag isn't very good), there was no other software installed, not even antivirus. The screen saver and power management features were disabled, and both tests were run at 1680x1050, 32K colors. Device Manager showed no unidentified devices under either O/S.
> The benchmark software ran 5 loops on each configuration to get a good average. While running, Task Manager showed around 60% utilization spread mostly evenly among both cores. RAM didn't seem to be an issue with 2GB or more still available during the test.
> The tests results show slightly lower scores (< 2%) for Windows 7 in the tested areas (3D, 2D, Disk, CPU), except for the 3D graphics index, which was 17% faster in Windows 7, and disk, which was 10% slower in Windows 7. The test took 38 minutes in Windows 7 and 39 minutes in Windows XP.
> Should Windows 7 make a bigger difference, or is this result typical?
> We do almost exclusively 2D graphics, so based on these results, it would be difficult to justify the cost of upgrading to Windows 7 to improve the performance of C3D 2010 (although it might make more of a difference for other applications).
> Should we be seeing different results? What would be the next area to try to optimize?
> If I purchase brand new computers, the best I could do would be to get a 3.3GHz Dual Core CPU with faster RAM and maybe a faster video card. It doesn't seem like it would make as dramatic a difference to replace three year old workstations as I would have hoped.
> Compared to other graphics applications, it seems like there are limited options for really improving C3D 2010 performance as long as it remains a 32-bit, single-threaded application.
> Do you have any suggestions?
> Thank you.
