All,
Below i show my table and its settings. Has anyone noticed/ solved this, or am i missing something?
My first impression is you are definitely short in excess of 21,000 (C.Y.?). Sounds negative to me if that is your question.
Bill
This table is coming from an after stance, We compared an original surface to a current surface. My net volume needs to be a fill value. Worst case senarion i can drop the sign because it is fill the whole way. Maybe I am looking at it wrong.
Is it possible when you compared the 2 you just got the base surface flip flopped? This would reverse the volume numbers.
Normally, I look at a job to see if it is balanced. In your case it shows negative which tells me I need to look for fill or re-design. Either way as you say, it needs fill.
Bill
Oops I misread this one, I agree with Bill, the negative value is correct for indicating fill/import needed, I took it to mean your Cut and Fill totals were switched around.
neilyj (No connection with Autodesk other than using the products in the real world)
Mark Green
Working on Civil 3D in Canada
