hello whoever is reading this post.
so basically i was ordered to draw a old plan which is around from 1950-60s.
in this old plan there are given dimensions, for example each line has its own bearings and distances.
however, drawing this plan takes forever. so in civil 3d, are there like programs or commands that automatically plots the drawing??
meaning if i copy and paste the pdf or png file into the autocad drawing, will the computer plots the drawing automatically?
thank you!
There are some third party tools which can convert a pdf file into CAD linework, but they're generally not all that effective. You`re probably better off recreating the drawing from the dimensions on the original.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
I'd give a try to the free Wintopo, sir.
Joe Bouza
tcorey wrote:
Raster Design is an indispensable tool.
I understand your VAR's approach, Timmy, but technically Wintopo does almost the same for free...
I appreciate the condescension, Antonito, but many of the readers here own Autodesk design suites and Raster Design is included therein. I was not trying to get anyone to purchase the software, just letting them know about a tool they already have.
Best regards,
Tim
