I need those two linear quantities above as shown:
Red (Fill) = 5.43
Blue (Cut) = 6.06
Is there a way for Civil 3D to generate those quantities for every section?
Assign the pay item to the code set style for the link and then use the Takeoff to get the quantity.
...Assign the pay item to the code set style for the link and then use the Takeoff to get the quantity.
Pay items for Links will give you areas, not linear link section lengths... Use corridor feature line reports.
You could do this with Generic Links that track the subbase behavior where you can assign link codes.
Use conditional cut/fill links, and pass subbase offset paramters to the generic links. Generate the report.
