Civil 3D Forum
Need Help with Image!
5 REPLIES 5
EJMartinez
334 Views, 5 Replies
Hello everyone,
Let me see if I can explain this clearly. I am about to turn in a few projects. I have to turn in everything using a DVD-R disc. One question that i really need help is the image I am using for the project. I am trying to turn it in with the image attach on. The problem is that the image has a path that goes to my computer to find the image. Another problem is that the image I am using is about 6.5 GB. I am only using a little area from this big image i got. I clip it in AutoCAD Civil 3d but it still has the 6.5GB. I am using Civil 3D 2012. I inserted the image using command MAPIINS. Image is an ecw file. I want to clip the image to the right file size to send off.
5 REPLIES 5
entropist
in reply to: EJMartinez
If you set all xrefs to relative paths, the links will work fine from any source.
I've never had to learn to clip images, but if you use a double layer DVD the image should fit as is.
EJMartinez
in reply to: entropist
Yea I set the image xref path to the right path I wanted. Its just the image is too big to send. Probably going to have to just send It using a big enough USB flash drive.
Neilw_05
If you really want to clip the image you should be able to de-compress it to a TIF or JPG using a utility from the makers of the ECW compression engine (ER-MAPPER?) and clip it with Raster Design or any other image editing software that supports georeferencing.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
antoniovinci
EJ,
I advise you to clip the huge ECW in a third-party Gis software (e.g. Qgis).
Doing so, you'll get a small georeferenced image, definitely portable by email...
EJMartinez
in reply to: antoniovinci
Will it work or is there a way to crop the image in AutoCAD Civil 3D 2012 or AutoCAD Map 3D 2012?
Rail Community
