I hadalready made one software which does all calculation part and gives ans in excel. Now i want to make its digramattic representation in autocad. I am using vs2010 vb.net . and have AutoCad 2014.
Is this possible to open autocad through .net and draw Digram. Digram is fix but it get repeated no of time with different reading . readings are available in excel sheet. is ts posssible and how. Please give me a some ideas.
I need to draw template once then just copy it but readings are change as per requirement. Need urgent help
Thanks in advance.
You would be more likely to get an answer to this question if you post in the AutoCAD Customization group.
