Valued Contributor
2 Kudos
Post 1 of 9
need help deleting surface
284 Views, 8 Replies
08-29-2013 01:28 PM
ok i have tried everything like selecting the surface from the procperctor and pressing delete but freezes civil 3d
i will email a link to the file to you and see if you can delete it
please someone help me
72 Kudos
Post 2 of 9
Re: need help deleting surface
08-29-2013 01:44 PM in reply to: htls69
what version?  I'll give it a go.  lpohlmeyer at wilco dot org
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
Valued Contributor
2 Kudos
Post 3 of 9
08-29-2013 01:50 PM in reply to: LisaPohlmeyer
using civil 3d 2014
send file to you
72 Kudos
Post 4 of 9
08-29-2013 02:10 PM in reply to: htls69
if it's larger than 8Mb, it'll bounce. You'll have to use Gdocs, Dropbox, or something else. Sorry.
Lisa Pohlmeyer
Valued Contributor
2 Kudos
Post 5 of 9
08-29-2013 02:15 PM in reply to: LisaPohlmeyer
i sent you a email with dropbox link
Valued Contributor
2 Kudos
Post 6 of 9
08-29-2013 03:29 PM in reply to: htls69
so she tried and she could not do it  maybe someone else can try
911 Kudos
Post 7 of 9
08-29-2013 03:41 PM in reply to: htls69
jeffm AT quuxsoft DOT com
I will have a look
Valued Contributor
2 Kudos
Post 8 of 9
08-29-2013 04:44 PM in reply to: Jeff_M
here is the file
here
Active Contributor
2 Kudos
Post 9 of 9
08-30-2013 03:34 AM in reply to: htls69
If you wont be able to delete surface after "audit" , just export everything to xml and import it to new dwg file
