Civil 3D Forum
Need an expression to round Pipe Slopes
12 REPLIES 12
Message 1 of 13
1390 Views, 12 Replies
We Need an expression to round Pipe Slopes to the nearest 0.5% slope.
We were working with:
ROUND(({Pipe Slope}/0.5))*0.5
but it only returns 0.00,
what's missing? THanks
12 REPLIES 12
Message 2 of 13
tcorey
I've done that with slopes on Section Views. I made two Expressions:
First, to find those values that should round to no decimal places:
IF(ABS({Grade between Point 1 and Point 2})-ABS(TRUNC({Grade between Point 1 and Point 2}))<0.25|ABS({Grade between Point 1 and Point 2})-ABS(TRUNC({Grade between Point 1 and Point 2}))>=0.75,1/120,0)
Note the | symbol between <0.25 and the next ABS means OR.
Second, to find those values that should round to .5:
IF(ABS({Grade between Point 1 and Point 2})-ABS(TRUNC({Grade between Point 1 and Point 2}))>=0.25&ABS({Grade between Point 1 and Point 2})-ABS(TRUNC({Grade between Point 1 and Point 2}))<0.75,1/120,0)
You might need to play with the 1/120 text height to get a height that works for you.
I assume you know how to make your label style use these. If not, let me know.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 13
in reply to: tcorey
Thanks for the quick response, I'm trying to add the expression to a pipe label style, need to round out the pipe's slope. Not sure how the "Grade between Point 1 and Point 2" plays out.
Why does picking the "Pipe Slope" function not play out?
THanks,
Message 4 of 13
tcorey
Look in the attached drawing. Find on Settings tab of Toolspace: Pipes --> Label Styles --> Plan/Profile --> Expressions.
These are referenced by the label style called Pipe slope - percent - rounded to .5. Apply that to your pipes and they will round to either no decimal places or .5.
Best regards,
Tim
Tim Corey
Redding, CA
Message 5 of 13
in reply to: tcorey
WOw, that's interesting, thanks , but unfortunately I'm dealing with 2012 and that percent function doesn't exist in the 2012 release, or I may be missing something. Thanks for the file though, just another reason to upgrade.
Message 6 of 13
tcorey
Here's a 2012 version.
Tim Corey
Redding, CA
Message 7 of 13
in reply to: tcorey
Thanks again for the 2012 version, but i think I'm not explaining myself correctly, I need to be able to round the slope percentage in the lable so that if the slope of the pipe is 3.42 as an example it will round down to 3.40, or if it is 7.47 it will round up to 7.50. The options of round normal , truncate and round up in the component editor don't seem to do the trick.
Thanks for your effort.
Message 8 of 13
tcorey
Sounds to me like you're rounding to the nearest tenth, which Civil 3D does without expressions. Your original post stated you want to round to the nearest .5, which is what the expressions I built do.
Maybe you can post a drawing with detailed description of what you want and that Civil 3D doesn't appear to be doing for you.
Tim
Tim Corey
Redding, CA
Message 9 of 13
in reply to: tcorey
okay, here's a dwg with a few pipe examples,
so basically to illustrate, if the slope is 4.54% so to say, we need it to read 4.55%,
if its let's say -3.32%, then we need it to read -3.30%
if 5.58%, we need it to read 5.60%
can't seem to get it to work with the given rounding methods
again, thanks for your efforts
Message 10 of 13
Civil3DReminders_com
Sounds like you are looking to round to the nearest tenth, but show two digits. This expresion should do it:
(ROUND({Pipe Slope}*10))/10
If you want the nearest 0.5% then this expression should work:
(ROUND({Pipe Slope}*2))/2
Christopher
http://blog.civil3dreminders.com/
Civil Reminders
http://www.CivilReminders.com/
Message 11 of 13
in reply to: Civil3DReminders_com
yeah, I started with those solutions but they still don't return the desired result.
If the slope of the pipe is -14.73% the (ROUND({Pipe Slope}*2))/2 expression returns 0.00%
If the slope of the pipe is -243.18% then  (ROUND({Pipe Slope}*2))/2 expression returns -250.00%
with the (ROUND({Pipe Slope}*10))/10 expression the results are -10.00% and -240.00% resepectively.
hmmm...
thanks for looking at the conundrum..
Message 12 of 13
Jeff_M
hmmm...
You are really wanting to round a number such as this: 0.14733689 (14.73%) to this: 0.1475. So this expression does just that: (ROUND({Pipe Slope}*2000)/2000  This gets the decimal point to the place that needs to be rounded.
Message 13 of 13
in reply to: Jeff_M
BINGO, WE GOT BINGO!
Thanks so much, the PEs will be happy, well at least for a little while.....
Rail Community
