Civil 3D Forum
Mysterious Alien Crop Circles
5 REPLIES 5
mcloughlin
561 Views, 5 Replies
In certain drawings that are re-opened, we find a little red 12-spoked crop circle at the 0,0,0 point.  It is not a base point; it is not a UCS reference (does not disappear when UCSICON is OFF).  It is not appended to any object; it sits alone unto itself.
The circle cannot be selected.  Consequently, it cannot be listed or otherwise manipulated.
As you can see in the appended image showing the same drawing zoomed out and zoomed in, the mystery circle does not zoom, and its distance from other objects increases with zoom amount if these are not centered at 0,0,0.  This image contains only the 0 and defpoints layers; turning off either layer does not affect the evil circle.
What can it mean?  How may I eliminate it?
I would add ghostly theramin music if it were possible.  Thanks for the help.
5 REPLIES 5
Pointdump
in reply to: mcloughlin
McL,
Hovering over the mysterious object, it says "Geographical Marker". Dunno.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
GEOMARKERVISIBILTY = 0. I'm not sure what its purpose really is, it tends to center itself within the bounding box of elements in the drawing.
That is the geospatial marker.
It is shown when a drawing has a geospatial coordinates system assigned to it. (Toolspace => Settings Tab => Right click the drawing name =>Units and Zone Tab of the the Drawing Settings dialogue => Zone group of controls at the bottom)
You can turn it off by typing "geomarkervisibility" at the command line (without the quotes) and setting the value to 0.
This will turn it off for the current drawing. To turn it off permanently, I have put the list command (setvar "geomarkervisibility" 0) in the acaddoc.lsp file.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Conor and Andrew,
Setting GEOMARKERVISIBILITY = 0 does indeed get rid of it.
Dave
Dave Stoll
Las Vegas, Nevada
Thanks, Andrew.  You have defeated the aliens successfully.
Rail Community
