ARC0112358 wrote:
> Well - in the Label Style composer there is no Text Style option.
> The only place I see a text style option in the Label Style composer
> is in the Text Component Editor under the Format tab but that won't
> let you change it from whattever it is set to in the Band Details
> window... Any more specific ideas?
> See the image below. I want the color 31 existing elevations to be a
> different text style that is obliqued. The three labels in this band
> are existing, proposed elevations and stati on numbers. The only
> place I seem to be able to edit the text style is in the Band Details
> window where you begin to define major, minor, blah blah labels. Do
> all labels in the band have to be the same text style??
No.
In the band details window, you have to define the "blah blah" labels
that you so eloquently describe. Once you select the label at the
major or minor stations, you can edit the label. You can edit the
label text, and select a font for this text. I've attached not only a
screenshot of where this is picked, but evidence that it can be done...
Jason Hickey
Civil 3D 2007, SP1A
Dell Precision M70
2 GIG RAM, 256 MB nVidia Quadro FX Go1400
Intel Centrino 2 gHz Processor
http://beneaththelines.blogspot.com
