LDT had a command for editing multiple lines of text without exiting the command. This made renumbering and relabeling very easy and saved time.
_TEDIT
Currently I am getting an error.
Command: (load "tedit")
; error: LOAD failed: "tedit"
Command: _TEDIT TEXTEDIT
Is there a similar command in C3D? Or can I edit the old command to be compatible with C3D?
Yes. That also only allows you to select one piece of text at a time. For example, if I have spot elevations numbered 1 - 20 and each number is it's own piece of text _TEDIT would allow you to select them all and go through each item, in order and you could fly through renumbering them hitting enter to go to the next number. I know this was very useful in LDT and I don't see why I couldn't get it to work in C3D.
