Hi!
I has a project where my Custom UCS don't is the Autocad's Original, but when I make Multiple Sections Views, the C3D does it in Autocad's Original UCS. How I make this on my Custom UCS?
Thanks.
Mark Green
Working on Civil 3D in Canada
Guys,
Here in Brazil we don't use C3D like a aCAD. See, I need to send my drawings in AutoCAD, and not in C3D. My plant don't uses UCS World because is inclined and don't is great to see project in inclined view.
If I make Multiple Sections View in Custom UCS, the Sections View comes with labels aligned with UCS World.
What I doing is exporting 2 times the drawing to aCAD; first with UCS World (for Sections View) and other to plant (with UCS Custom).
PS.: My english don't is great, sorry for this.
Thanks.
Mark Green
Soory I have to add my 2 cents and admit I would never recommend anyone ignoring the UCS command. It may not work with some C3D commands and at worst you may get unexpected results using a UCS with some C3D commands but UCS's are a powerful tool for hatching, annotating, viewing and drafting. I have never seen file corruption or crashes using a UCS with LDD or C3D. The big secret is just making sure you are in world coors if executing a C3D command. After that anything is possible.
John Mayo
Mark Green
Joe Bouza
Joe Bouza
Thank you Joe for picking up the ball I dropped. :0
Sorry I let this slip troma.
A bit more. Dimensions can have text aligned to the plot or object w/o having to set a text angle. If you need to hatch multiple objects a different angles set the ucs to the object, hatch and move to the next. You can also use these tools to help construct acad objects relative to other acad objects again just by selecting a line at your desired angle.
It's a shame UCS's and views can't be ported between files as this would save more time. There are pro's and cons to each methods that vary by workflow. We just like keeping all the plans and labels consistent without anyone having to guess about the angle or object to align stuff to.
John Mayo
Joe Bouza
Mark Green
