AutoCAD Civil 3D General Discussion
Active Contributor
ashleystrand
Message 1 of 4 (95 Views)
Multiple Profiles on Plan and Profile Sheet
95 Views, 3 Replies
08-05-2013 11:19 AM
How can I show two proposed alignments in one plan and profile sheet?
john.mckenzie
Message 2 of 4 (91 Views)
Re: Multiple Profiles on Plan and Profile Sheet
08-05-2013 11:37 AM in reply to: ashleystrand
are you using sheet set manager or just setting them up on the fly with manual viewports etc.
john.mckenzie
Message 3 of 4 (89 Views)
08-05-2013 11:40 AM in reply to: john.mckenzie
I usually datareference the ailgnments so that is easy enough to do twice.
I usually do my profile work in a file that I xreference in.
if there is enough room on the sheet, you can have both alignments showing and stationed. then show both profile views in separate viewports below and you are done.
I set my sheets up manually because I find it is easy enough to do and many times my workflow is not linear. A sheet set needed today is not always the one I need the next day or the day after.
Active Contributor
ashleystrand
Message 4 of 4 (86 Views)
08-05-2013 11:42 AM in reply to: john.mckenzie
I'm using the sheet set manager followed by "Create View Frames".  This is my first time creating plan and profile sheets.  I data reference both of the alignments and profiles.
Need installation help?
