hopefully someone can help me out. How can I show 4 profiles in one profile view ? I have 4 sets of asbuilt coordinates for 4 different levels during a construction (original ground, bottom of ditch, top of UG pipe, finished grade) and need to show their in different colours all in one profile view. I know how to create a profile/profile view from an alignment but would appreciate a step by step instruction how to do the above described. Thanks a lot.
Solved by jeff_rivers. Go to Solution.
Solved by Jay_B. Go to Solution.
Not sure if I am right but since I need to show the stationings I will probably have to go with the profile created from an alignment. So my question still stands - how to put more profiles (created from an alignment) into one profile view ? Thanks.
Once the profiles belonging to the same parent alignment have been created, just create a Profile View and when prompted for "Profile Display Options" be sure to toggle the display of all desired profiles to be displayed.
If you already have a profile view the profiles will be automatically drawn/available in the profile view.
Display of the multiple profiles in a given profile view can be managed here:
Profile View Properties > Profiles Tab.
one more quick question - how do I show labels with stationing and elevation in the profile view for the points defining the profile (the PVI's) ? Thanks
