I am currently working in AutoCAD Civil 3D 2013. I am trying to use the Plan Production feature to create my profile views. The project does not have a large difference in elevation from begining to end so the profiles are relatively flat. Therefore I would like to fit multiple profile views stacked over each other per layout. Is there a way to set up the viewports in the template or is there an option in Plan Production to make this possible? Thank you.
Solved by Joe-Bouza. Go to Solution.
You have to run as one then manually move to the wanted layouts
Your Name
Thanks for the "info".
Looks like I'll just have to keep muddling along here in the dark with the rest of the schmucks until you deem us worthy of your intelligence.
Mark Green
Working on Civil 3D in Canada
