AutoCAD Civil 3D General Discussion
0 Kudos
Post 1 of 8
MULTIPLE PARCEL STYLES TO ONE PARCEL
287 Views, 7 Replies
03-19-2014 10:30 AM
Hey is it possible to apply multiple parcel styles on one parcel.
I ask this beacause I have my parcels xref'd into other dwg files.
However i need the parcel number and area in some files.
Whereas in others I need the parcel number only.
But because they are both in one style there is no turning off one or the other.
I hope I have not confused anyone.
Thanks in advance for all the help. It is greatly appreciated.
*Expert Elite*
132 Kudos
Post 2 of 8
Re: MULTIPLE PARCEL STYLES TO ONE PARCEL
03-19-2014 02:11 PM in reply to: Ash254
How about controlling the visibility of your information with layers? That way you wouldn't need more than one style.
Dave
Dave Stoll
Mohave Valley, Arizona
Intel Core i7-3820QM 3rd Generation Quad Core 2.7 GHZ CPU
16 GB DDR3 RAM ( 2 DIMM ) / 180 GB SSD
Nvidia GeForce 650M Graphics w/2 GB Memory
Windows 7 Professional 64 bit / AutoCAD Civil 3D 2014/2015
*Expert Elite*
326 Kudos
Post 3 of 8
03-19-2014 03:13 PM in reply to: Ash254
you can lable parcels through an xref. a method a I saw on a AU video showed the parcel label in the base file on a no plt layer, and then the sheet file labled using its own style
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
0 Kudos
Post 4 of 8
03-20-2014 06:41 AM in reply to: Ash254
Hey thanks for yall input
-Mr. Dave believe you me I tried that layers thing but i am using one Parcel area label style with two components (parcel area and parcel number).
 So its all on one layer there is no way I saw to separate them on different labels
-Mr. Bouza I tried labeling the parcels in the file it was xref'd  into. I was only able to get things such as bearings and distances but I'm still unable to  do nothing with the areas or lot numbers.
I am not sure if I have missed something which either of you guys meant.
Go easy on me I am no where near being as accomplished as you guys with Civil 3d
*Expert Elite*
326 Kudos
Post 5 of 8
03-20-2014 07:12 AM in reply to: Ash254
Works for me.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
0 Kudos
Post 6 of 8
03-20-2014 07:32 AM in reply to: Joe-Bouza
i get it now i did not use autocad sheet set for this particular project. it was not giving me me the layouts the way i required. thanks alot for the help though i would try that later on this afternoon
Let me tap some more on your knowledge a bit more
This is way off topic of what I previously asked but
lets say i created cross-sections along a road 400m long at every 10m.
However now I would like for other purposes to plot them in groups of 50m.
But I still want both sets, every 10m and every 50m in the same dwg file without duplicating sample lines.
*Expert Elite*
132 Kudos
Post 7 of 8
03-20-2014 05:15 PM in reply to: Ash254
Ash254,
You're right. The Parcel Style won't separate each line of information into different layers. I thought it might but I was wrong.
Joe's solution looks good. I'm going to try it. The only other possibility I can think of is a General Label Style for each line. I'm not sure how to link it to the Parcel Label.
Dave
Dave Stoll
*Expert Elite*
910 Kudos
Post 8 of 8
03-20-2014 06:15 PM in reply to: Ash254
Ash, I do as Joe described. In the drawing contains the parcel xref, choose add parcel area labels and select the area label in the xref. Even works by window/crossing selection to get many at once.
For your sections question, I suggest starting a new thread to ask this. Otherwise someone who might know the answer to that, but not the label question, may never even see the question.
Jeff_M, also a frequent Swamper
Post to the Community
New Post
