Can you post a screen shot of what your seeing?
An Export to DWG 2010 from 2014 seems to work fine here with no extra unexpected numbers etc.
Save it as a png file and place it in the body of post using this icon:
@dimensionsdrafting wrote:
Hmmm - I don't see any Icons at all. I found an older post where someone was having the same problem however there was never a solution posted. I'm using the current version of IE. Thanks!
Not sure if this helps but if I'm on the "HTML" editor tab, then I don't see any icons here either, but on the "Rich Text" editor tab they are present.
Please post a file that exhibits the issue or a screen capture showing us what it is your seeing, otherwise we're just guessing.
