I receive text files daily from our survey crew. Importing each point file daily creates mulitple import events under the database. Is there a way to combine import events to make it easier when wanting to work with all points ?
I have combined multiple text files in the past then did the import, but I then would receive another file some where down the road that would needed added to the drawing.
Thanks in advance for any assistance....
You could import all of your points into the same network. What are you trying to do when you 'work with all points'? We don't typically edit the survey data in the import event. We do it in the network.
Thanks Kirk...Still farely new to Civil and thats all I need was a nudge in the right direction. I just created a network and then imported point files to the network. I see there are still multiple import events, but if needed I can edit points thru the network. Thanks Again
