Civil 3D Forum
Multiple contour intervals on one surface?
3 REPLIES 3
Tech_bd
567 Views, 3 Replies
I have a surface with elevation ranges from 500.00' to 525.00'. I need to show 2' contours as well as the 515.00' contour. Is there a way to add a contour to the surface while keeping the 2' interval?
3 REPLIES 3
Jay_B
in reply to: Tech_bd
Surface Properties > Anaylisis Tab > Analysis Type: User-defined contours > Ranges: Enter # of user contours you'll have.
Press the down arrow next to ranges to push it to bottom > Enter Elevation 515 in "range details" apply.
Then to edit Surface Style in use > Display Tab > Turn on "User Defined Contours"
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
tcorey
Make the 515' contour a User Defined Contour.
In the Surface Style, turn on User Contours (Display tab.)
In the Surface Properties, go to Analysis tab, set Analysis type to User-defined contours, set number of ranges to 1, press the down arrow, and in the table change the elevation to 515.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Tech_bd
in reply to: Jay_B
Thank You!
Rail Community
