Civil 3D Forum
multiple baselines within a coridor
5 REPLIES 5
albert
1458 Views, 5 Replies
Need HELP please!!!! I have a open ditch corridor with a single alignment but have multiple baselines - the problem I'm having is it's only showing one surface within the corridor. Obviously the the other baselines are not showing up. Am I missing some links or what not.
5 REPLIES 5
albert
in reply to: albert
Here's (see attached) the project I'm working on. The first baseline's surface is missing - there's a box culvert that seperates these two baselines.
doni49
in reply to: albert
Are you sure you've added the second BL to the corridor?  Did you set up the REGION for the second BL?
Post a screen shot of the PARAMETERS tab of your corridor properties (like shown below).
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
callen
in reply to: doni49
If you have the "corridor extents as boundary" on, turn it off and rebuild.  I bet your surface magically appears.
sboon
in reply to: callen
callen probably has it right.  You will have to create a boundary using the daylight feature lines, or draw your own polygon.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
albert
in reply to: doni49
Thanks Doni 49, callen and sboon for you input. It's working now after I've created a polygon as corridor boundary.
Rail Community
