Need HELP please!!!! I have a open ditch corridor with a single alignment but have multiple baselines - the problem I'm having is it's only showing one surface within the corridor. Obviously the the other baselines are not showing up. Am I missing some links or what not.
Solved by albert. Go to Solution.
Solved by sboon. Go to Solution.
Solved by doni49. Go to Solution.
Here's (see attached) the project I'm working on. The first baseline's surface is missing - there's a box culvert that seperates these two baselines.
Are you sure you've added the second BL to the corridor? Did you set up the REGION for the second BL?
Post a screen shot of the PARAMETERS tab of your corridor properties (like shown below).
Don Ireland
Engineering Design Technician
callen probably has it right. You will have to create a boundary using the daylight feature lines, or draw your own polygon.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Thanks Doni 49, callen and sboon for you input. It's working now after I've created a polygon as corridor boundary.
