I am working on the approach geometry for a roundabout and need to call out the necessary information for laying out the edge of pavement (EOP). I have my main center line of road alignment and have created new alignments from polylines that "ride" over top of the EOP. My plan was to use the line and curve alignment labeler and then create a table with all of the geometric information contained within. This worked out great, except that I want the station references along the EOP station call outs in the table to reference my center line alignment, and not the alignments that I created to collect the geometric information over the EOP. Explaining in more detail, when the "line" table calls out the begin and end station limits, I want it to reference the location of those limits on the centerline alignment that is at a varying distance away from the EOP alignment. Any help on this topic would be very much appreciated! Thank you in advance!
I attached a screen shot as well.
The closest thing I can see included in Civil 3D is the Alignment Station Offset to Points report. I guess if you had points set at the start and end of the segments you could use that report. Not dynamic though, and not inclusive of everything you'd like to show.
Mike
This can be done as a label, but I don't see a way to create it as a table.
Right. The tables do not support Reference Text like the Labels do.
Yet another idea for a custom app....
Mike
While we do have a tool to dynamically update the station/offset values for CogoPoints in relation to any alignment, and these can be shown in a Point Table, I don't see any way of combining the data into the Line table as the OP is requesting.
