Civil 3D Forum
Multiple Alignment Section View
3 REPLIES 3
586 Views, 3 Replies
I'm trying to show some sections of my current project that has two parallel rail lines created via corridor. However, I cannot figure out how to draw section views of the corridor that shows both my main rail alignment and the secondary rail alignment. They are together in 1 corridor, but are separate alignments.
Is there a way to do this?
3 REPLIES 3
Depends, what does the assembly look like? Sections will only pick up one
baseline, so they'd have to be in the same baseline to work. Otherwise, you
can only get the surfaces.
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2007
XP Tablet, SP2, 2GHz, 2G
www.eng-eff.com
www.civil3d.com
There's are two assemblies. One for the 'main rail' alignment, and a different assembly (basically a mirror) for the 'secondary rail spur' alignment.
So yeah, they are in two separate baselines.
cadtown
Download & install Section3D from the following link:
http://www.cadmicro.com/categories/c-pro-3-tools-c-civil3d.htm
If you e-mail me the reg number I will send you the license.
If you have the patience to go through the tutorial, I guarantee that you will find what you are looking for and more...
Peter,
Rail Community
