Active Member
fordtruckman
Message 1 of 5 (519 Views)
Multiline text being converted into separate multiline texts
519 Views, 4 Replies
01-09-2013 02:09 PM
I've recently noticed that my multiline text boxes in old drawings have been splitting themselves into multiple multiline text boxes.  They aren't exploding into single line text because it won't let me use the convert command to turn them into multiline because they are already multiline.
I know the dimassoc command can be set to a certain value to cause all dimensions to explode but is there some kind of command that could have change itself and is causing this problem?
Hopefully that explanation made sense...
Thanks for the help!
*Pro
dgordon
Message 2 of 5 (496 Views)
Re: Multiline text being converted into separate multiline texts
01-10-2013 11:11 AM in reply to: fordtruckman
mtext boxes do not just split them selves.   They don't explode into multiple mtext boxes either.   They explode to dtext.
I've never seen what you're seeing.   I can just tell you that is not typical behavior.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Active Member
fordtruckman
Message 3 of 5 (477 Views)
01-14-2013 06:16 AM in reply to: dgordon
Ok so even if they explode themselves to single line text blocks then there still isn't a command that controls that?
I was hoping it was some kind of setting that auto-exploded multiline text.  Don't know why you'd ever want that but, was hoping that existed so I could fix my issue.
Distinguished Mentor
rl_jackson
Message 4 of 5 (472 Views)
01-14-2013 06:39 AM in reply to: fordtruckman
I got this lisp routine on this discussion board some time ago, it converts multiple dtext objects to single mtext objects.
Hope that helps
Rick
C3D12-13
Win7x64 6gb
Active Member
Edwin
Message 5 of 5 (65 Views)
10-23-2014 05:41 PM in reply to: rl_jackson
You are an ACE.jpgmate!
THANKS...that was real helpful.
