Civil 3D Forum
Multileaders
6 REPLIES 6
teflon
1353 Views, 6 Replies
Multileaders
My Multileaders have an elevation, Z value! Is there a quick way to set the z value to 0?
6 REPLIES 6
DaveM
in reply to: teflon
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
teflon
in reply to: DaveM
Thanks!
teflon
in reply to: DaveM
Good solution but everything got exploded! So they are not annotative multileaders anymore!
I tested both options "Removing hidden lines"  and not "Removing hidden lines".
I do not understand why the multileaders got the elevation to begin with!
teflon
in reply to: DaveM
Something like OSNAPZ which could be used afterwards!
Ajilal.Vijayan
in reply to: teflon
Try with this code
(defun c:MLZ (/ key alist e n obj pts ss)
  ;from http://www.cadtutor.net/forum/showthread.php?30800-Polyline-Vertex-Question&p=198725&viewfull=1#post...
  (defun massoc (key alist / x nlist)
  (foreach x alist
    (if (eq key (car x))
     (progn
	 (setq alist (subst (cons key (list (nth 0 (cdr x))(nth 1 (cdr x)) 0)) x alist))
	 );progn
 );if
  );foreach
  );defun
  (setq n -1)
  (if (setq ss (ssget ":L" '((0 . "MULTILEADER"))))
    (while (setq e (ssname ss (setq n (1+ n))))
	(entmod (massoc 10 (entget e)))
    );while
  (princ)
);defun
teflon
in reply to: DaveM
What I came up with is to make a block of all multileaders and then set the block to z=0 and then explode the block.
Rail Community
