So the leader in the following picture shows the arrowhead attached to the leader as expected:
But when I open a template drawing I have created the same multileader displays as such:
Notice the extremely large gap between the arrowhead and the leader? What is defining this distance?
I have tried the ACAD built-in blocks (_open, _origin2, etc.) as the arrowhead and they all display with the gap. What gives? I'm seeing this in C3D 2015, not in C3D 2013.
Thank you for your question. The Multileader's linetype is set to "By Layer" and the layer's linetype is Continous.
Very strange, can you duplicate the issue by creating an mleader style, in a dwg using the ootb, acad civil imperial NCS .dwt ?
Using the above template in I can't seem to replicate the issue here using 2015 SP1.
Rick Jackson
Survey CAD Technician VI
I take it the arrowhead is a block... check the block's units, was it created in feet or unitless etc. check your drawing units. Verify the insertion point of the block.
@Grimes_MG wrote:
I have tried theACAD built-in blocks (_open, _origin2, etc.) as the arrowhead and they all display with the gap. What gives? I'm seeing this inC3D 2015, not inC3D 2013.
It does appear the OP is possibly using a custom block for the arrowhead.
The original post states that 2 of the ACAD built-in blocks (_open, _origin2, etc.) , exhibit the same gap issue in the problem custom template.
