Does anyone have idea how I can create my multi-view block and access it through the "Insert" dialog box or through the Tool Palette? In fact I tried to create and use Power Pole multi-view block, I actually created the View blocks but after creating the named Multi-View block it vanished. It was neither in the Insert Dialog Box nor in the Tool Palette.
Solved by MarySeufert. Go to Solution.
Yes, I created my view blocks and when I used the "Edit Multi-view block" tool to create my named multi-view block, that named multiview block vanished into thin air. The named multiview block could not be located the "Insert" Dialog Box nor in Tool Palette nor in Design Center.
What Mary's screen capture was showing is the command for adding Multi-View Block to your file. They are added with the command "AecMvBlockAdd" and not with the "Insert" command.
Peter Funk
I think Mary's capture and "AecMvBlockAdd" command pertains only to a situation where you already have mvblock reference in your drawing and wish to add more instances of the same block. What I was saying is that I created view blocks with which I created MV block. Thereafter I could not see the my MV block again. I could only see the Autodesk predefined MV blocks in the Tool Palette but not the one I created.
Making a Multi-View Block doesn't add it to the tool palette and it won't show in the Insert dialog because it isn't a Block it is a MVBlock.
Peter Funk
Have any idea how Autodesk, Inc created their MV Blocks that were accessible through the Tool palette? Drawing files for those MVBs were located at C:\ProgramData\Autodesk\C3D 2012\enu\Data\Symbols\Mvblocks. I created my own MVB drawing file inside this Mvblocks folder with hope that my MVB will also be listed along in the Tool palette but that didn't happen.
@Anonymous wrote:Have any idea how Autodesk, Inc created their MV Blocks that were accessible through the Tool palette?
They created the stock tool palettes in the same way you would make your own. Drag and drop the MVB from your MVB drawing file to your tool palette. You can also use Design Center to insert MVBs. Look at the link in my original post, and Jeff's for the Help files to guide you through it. Matt's suggestion is valid and it is how the stock MVBs in Civil3D come, but not a necessary step from my experience.
What is interesting to me is the difference in how MVBs are managed in ACA(AMEP) vs. C3D. Civil3D does not have a user friendly way to manage them. I would like to see them incorporated into the Toolspace in some way. They are created/maintained in ACA through the Style Manager which is similar in effect to the Settings tab of Toolspace.
~ Mary
