Civil 3D Forum
Multi select causes civil 3d 2012 to lose focus
2 REPLIES 2
Steve030373
246 Views, 2 Replies
Has anybody encoutered this before:
When making a selection of multiple anything by window, after the selected items are highlighted by civil.... you are misteriously and without notification Switched focus! Civil 3d is no longer the current program Running! You have to click on the Task bar and then click again in the civil 3d window to be active in civil 3d again. Then you can proceed as normal. Until you select by window again, and then you have to do the Click outside civil and click inside civil. It's as if Civil 3D loses focus when you select multiple items.
Any help with this would be much appreciated.
2 REPLIES 2
tcorey
in reply to: Steve030373
Yikes. Is your Civil 3D window maximized? Does this happen if nothing else is running?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Steve030373
in reply to: tcorey
Tim,
  Yes it happens if nothing else is running and my civil 3d windows is maximized.  I don't really know what is going on, but loosing focus is the best way to describe it. It is as if the computer switches to another program but the display doesn't change other than my crosshairs become a standard pointer.
Rail Community
