I had a post over there as well Drew. I have not worked with annotative
objects since I ran into this issue. I don't know how I can use this feature
without telling the users that they have too set all of the scales
individually & copy those objects. I would appreciate you posting anything
new on this.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008, LDT 2008, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
"Drew Burgasser" wrote in message
news:5587990@discussion.autodesk.com...
Hi John:
That is a good question.
AFAIK, you first have to create the annotation objects, and THEN apply the
scales. I would think that there would be a way to set the scales you want
to use. But I haven't found a way to do this.
Nrhoads posted the question on the AutoCAD 2008 newsgroup, but he didn't get
any replies that directly address the question. I'll try to post it again.
Sincerely,
Drew Burgasser
CAD Masters, Inc.
www.cadmasters.com
"John Mayo" wrote in message
news:5587698@discussion.autodesk.com...
Thank-you for the post Drew.
Do you know if it is possible to set up an annotative dim or text style that
has a pre-defined list of scales.
I would like one dimstyle in the templates to plot at 10,20,30,40,50 & 60
scales, another to plot at scales 100 & above & a third to plot at scales
less than 10.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
news:5587077@discussion.autodesk.com...
Perhaps the leaders are annotative? And you need to add the annotation
scale for those objects for your particular viewport scale?
Try setting annoallvisible to 1 to at least see if that is the problem. If
it is the problem, set it back to 0. Type objectscale in modelspace and add
the desired annotation scale for all of the annotation objects.
Sincerely,
Drew Burgasser
CAD Masters, Inc.
www.cadmasters.com
wrote in message news:5586954@discussion.autodesk.com...
Ok so I've got a co worker who created some sections in Civil 3D and used
multileader on them all in model space of Civil 3D 2008. Now in Model space
you can see the leaders and text. When you go into paperspace and create a
viewport the leaders and text do not come through. Brand new viewport,
nothing preset. So how do I get the multileader text and leaders to be
visible in the viewport?
Heidi
