Civil 3D Forum
Multi corridor surface
7 REPLIES 7
Message 1 of 8
226 Views, 7 Replies
Can I add different corridors to a corridor
surface?
Thanks, Joe
Joseph D. Bouza, P.E. (one of 'THOSE' People)
Civil 3D 2008
Win XP
pro
v 2002, sp 2
hp workstation xw4600
Intel Core Duo CPU
E7200
@2.53 GHz
3 GB RAM
NIVDIA Quadro FX 1700
(512MB)
"All Contours are Lies! "-(
AJ)
The mantra of a former Flamer:
If you
are forced to eat an Elephant, don’t complain about it; Take one bite at a
time.
In
memory of the King of Work-arounds
"The only Constant is Change".
"The only thing worse than training your staff, and having them leave is
not training your staff, and having them stay." 😮
A reminder taken
from Graphics Solution Providers' Calendar
page
"An
Equal Opportunity Annoyer" (DK)
7 REPLIES 7
Message 2 of 8
Paste them together in a new surface.
John Mayo, PE
Core i7 920 6GB DDR3
Radeon 4870HD 1 GB
Vista64
Message 3 of 8
Thanks. So no dynamic surface?
Message 4 of 8
If you had everything set to auto rebuild it would be. No?
John Mayo, PE
Radeon 4870HD 1 GB
Vista64
Message 5 of 8
castled071049
Changes made to any child surface will update the parent surface at each rebuild of the parent. This is probably the best way to build a surface from multiple sources (corridors, other surfaces, etc.)
Just remember that the last surface pasted in wins out over any previously pasted in and underlying surfaces.
Message 6 of 8
Oh I never realized that worked like that. I
assumed once pasted it became static. So I can paste surfaces together and edit
the parent and be current. That is great news.
Message 7 of 8
castled071049
In re-reading my post, I think I used the words "child" and "parent" backwards, although your conclusion is correct despite my miswording. In summary, any changes made to individual surfaces that are pasted into a larger "composite" surface will update the composite surface on the next rebuild of the composite. Changes made to the composite surface will not, of course, reflect back to the smaller individual surfaces.
Note that if the individual smaller surfaces are pasted in from a data shortcut, then any changes to the individual surfaces will have to be saved and synchronized in the composite surface drawing file in order to take effect.
Message 8 of 8
BrianHailey
> {quote:title=castled071049 wrote:}{quote}
Actually, with the new tools in the Subscription Advantage Pack, it can sort of do this. You can create a cropped surface. This is a piece of a surface in a new drawing that uses the larger surface as a data source. Changing the large surface will update the small surface but changing the cropped surface will not change the larger surface. Come to think of it, it works just the opposite of pasting surfaces.
Brian Hailey
http://www.cad-1.com
http://www.AtYourDeskTraining.com
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Rail Community
