Civil 3D Forum
MTEXT JUSTIFICATION
4 REPLIES 4
wbrustle
1406 Views, 4 Replies
MTEXT JUSTIFICATION
I am editing mtext and I am not sure exactly at what justification it was originally created, and everytime I edit the mtext when I complete my edit and accept changes and exit out of the command the mtext jumps to a new location. How can I change the justification to this already established text within my drawing so this does not happen? The mtext is middle center justified. I know if I create new mtext at middle center justification and make an edit, the text does not move......its just with this other text that was already in the drawing......thanks
4 REPLIES 4
troma
in reply to: wbrustle
Is it actually mtext? Sounds like a multileader to me.
It could be a multileader with no leader attached; if so I believe the behaviour you report is a known bug. Happens to me too. Quite annoying.
Mark Green
Working on Civil 3D in Canada
wbrustle
in reply to: troma
I just checked and it is a multi-leader with no leader. I do this quite often while drafting....I copy around my text starting with a multileader, this way I have a leader I can attach or detach as I need it. I just never knew why the multileader text behaved this way.......well I know now and thank you very much...it was driving me crazy too. Maybe someday they will fix this issue.
troma
I've used them too; useful for maitaining a box around the text.
One workaround is to keep them left justified.  I think the problem only occurs with centre or right justification (and only when there is no leader).
If you don't need a box around your text, I suggest exploding it to mtext for now.  Then use the lisp posted here to convert it to a multileader if & when you need to.
Mark Green
wbrustle
in reply to: troma
Thank you very much. I will def. check it out
Rail Community
