326 Kudos
Post 11 of 22
Re: MTEXT Field data location
10-19-2012 02:26 PM in reply to: atklump
Does it matter? My first response is correct; there is no way (with out programing) to get c3d info int a field.
Cut and paste, but that would be double posting a double post :smileysurprised:
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
161 Kudos
Post 12 of 22
10-20-2012 08:06 AM in reply to: atklump
Deflections are included if you use an Alignment with your pipes.  It is under Label Styles, Tangent Intersection.
Bill
326 Kudos
Post 13 of 22
10-20-2012 12:31 PM in reply to: wfberry
yes but you can't access it from the structure label style
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
0 Kudos
Post 14 of 22
11-02-2012 02:26 PM in reply to: Joe-Bouza
Sorry Joe,
No luck on the multiling labeling in GIS.  Our two GIS guys don't work with labels often enough to know.
326 Kudos
Post 15 of 22
11-05-2012 05:51 AM in reply to: atklump
Thanks for looking
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Employee
88 Kudos
Post 16 of 22
11-05-2012 01:17 PM in reply to: Joe-Bouza
Civil 3D doesn't have a pipe line / structure label like this of label built in.
I would make two labels and place them on together. The structure label would label the size and number, and the aligment label would label the turned angle. I might add a short line seg to the "top" label so that I could snap the "bottom" label into position.
Peter Funk
Peter Funk
326 Kudos
Post 17 of 22
11-05-2012 01:49 PM in reply to: peterfunkautodesk
Thanks Peter
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
0 Kudos
Post 18 of 22
11-27-2012 02:02 PM in reply to: peterfunkautodesk
Peter,
It appears you are an employee of autodesk.  Could you find out why wouldn't autodesk have labels generated to function similar to mtext?  Be able to add fields to the labels, and make it annotative to improve efficiency of labeling?
They made something that seems very robust, but if the general user can't figure it out intuitively, then it is relatively worthless.  Small companies can't afford the additional training required to optimize this stuff, especially when it can barely afford the subscription.
The work around doesn't work when you have it oriented different in various viewports.
Thanks for the suggestion though Peter.
Adam
Valued Mentor
40 Kudos
Post 19 of 22
11-27-2012 05:05 PM in reply to: Joe-Bouza
Joe,
not sure if I completely grasped your question about multiline label (your question was on ArcGIS or Map 3D?), but are you trying to add labels composed of multiple lines pulling info from different attribute fields in ArcGIS? if so, you may be able to accomplish what you need with VB label expression using the  vbCrLf function. please see attached image for an example, labels the drainage area name, divides the sq.ft area by 43560, rounds it, and labels the arcreage in the second line.
Avishek Chhibber, P.E., CFM
Civil 3D 2014 SP2, Win 7-64 bit
8GB RAM
326 Kudos
Post 20 of 22
11-27-2012 06:45 PM in reply to: Joe-Bouza
Hi YoungPE,
It the Mad3d I'm working in, I have since gotten into the expression builder, but in 2012 the enhanced label interface added a wizard that does do what I intuitivly expect it to do.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
