Valued Contributor
inhl
Message 1 of 5 (454 Views)
MSE Retaining Wall Assembly?
454 Views, 4 Replies
05-27-2009 08:54 AM
Does anyone have a MSE Retaining Wall subassembly? or any type of retaining wall subassembly that does NOT have a footing or let me know where I can find one?
TIA
chudlundgreen
Message 2 of 5 (382 Views)
Re: MSE Retaining Wall Assembly?
02-09-2011 09:58 AM in reply to: inhl
I've been looking for one too.  I can't say I've found one.  I started making alignments for each layer of reinforcement which is very tedious and I don't recommend it.
jeff_rivers
Message 3 of 5 (363 Views)
02-09-2011 02:53 PM in reply to: inhl
I did a project with an MSE wall recently and built the wall using generic links.  I did not model the tiebacks if that is what you need.
I used a preliminary corridor to establish the toe-of-wall and top-of-wall profiles and alignments.  I can send you the road and wall assembly but it is pretty simple: From the shoulder a link width-and-slope targets the toe of wall, then a link slope-to-elevation targets the top-of-wall profile at a constant 1:6.  Then a link-to-marked-point targets a previously-marked point on the road shoulder to finish off the top of the wall.
I used a separate corridor to develop the wall excavation volume.
Win 7E 64-bit, Intel i7, 12 GB
C3D 2012
chudlundgreen
Message 4 of 5 (352 Views)
02-09-2011 04:15 PM in reply to: inhl
Yeah, I'm looking for a subassembly that has the reinforcement too.  But thanks for your help.  I might be able to try that and get some of a design.
Member
ABUSAIF2000
Message 5 of 5 (148 Views)
11-06-2012 10:53 AM in reply to: jeff_rivers
Hello, Jeff, I saw your post abbout the MSE wall ,  im trying to draw an mse retaing wall project, I been looking around if there is a lisp or a program that does that, any luck in your side?
