Im have an drawing with a sid file in it, created it last week. The drawing worked great but I opened it up and the sid image no longer showes up. I get the message "There was a problem adding data to map."
Do I have any options? Am I doing something wrong?
Was the image inserted or are you using FDO in Map.
Allen
Allen Jessup
CAD Manager - Designer
The first thing I'd check is that the image is still in the same path as when you attached it. If it is. The next thing is to Disconnect and Reconnect to see if that solves the problem.
Allen
Allen Jessup
What happens if you import the MrSID file thru the _MAPIINSERT coomand..?
We had this same problem. It turned out that you need to have full rights to the "temporary external references file location". We had directed this to a custom path but if we left that location to the default "C:\Users\username\appdata\local\temp" it fixed the problem.
