Civil 3D Forum
Mr Sid Image ssues Civil 3D 2014
7 REPLIES 7
Message 1 of 8
jimsoehner
631 Views, 7 Replies
Im have an drawing with a sid file in it, created it last week.  The drawing worked great but I opened it up and the sid image no longer showes up.  I get the message "There was a problem adding data to map."
Do I have any options? Am I doing something wrong?
7 REPLIES 7
Message 2 of 8
AllenJessup
in reply to: jimsoehner
Was the image inserted or are you using FDO in Map.
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 8
jimsoehner
in reply to: AllenJessup
Using FDO Map
Message 4 of 8
AllenJessup
The first thing I'd check is that the image is still in the same path as when you attached it. If it is. The next thing is to Disconnect and Reconnect to see if that solves the problem.
Allen
Allen Jessup
Message 5 of 8
antoniovinci
What happens if you import the MrSID file thru the _MAPIINSERT coomand..?
Message 6 of 8
jimsoehner
Spoiler
I have tried that.  Thanks
Message 7 of 8
jimsoehner
in reply to: antoniovinci
Get same problem.
Message 8 of 8
zoeyanne
We had this same problem.  It turned out that you need to have full rights to the "temporary external references file location".  We had directed this to a custom path but if we left that location to the default "C:\Users\username\appdata\local\temp" it fixed the problem.
Rail Community
