I am trying to insert an Mr Sid file using Data Connect. I am running 2011 C3D. When I try adding the file to the dwg, it tries to execute the query, but then I get an error "There was a problem adding data to map."
The folder containing the SID file has two other files...the .sdw file and the metadata file. Is there another file missing? Or is the SID file too large...it's 1.6GB.
Do I have any options? Am I doing something wrong? thanks
The Zip file for the Sid Should contain: *.sid,*.sdw,*.aux,*.shp,*.prj,*.dbf
Try using the Image>Insert comand and set the projectins in the popup dialog.
Jim
Have you installed the Raster Helper. It is a free download from AutoCADD.
