Solved by mjohnston. Go to Solution.
If you only want the outline, you can also use the Polydisplay variable to toggle the fill off and only show the edges. *stolen from the innernetz* MPolygon objects are custom entities defined in Autodesk Map (and Land Desktop, Civil 3D). They serve primarily for representation of multi-part polygons (e.g. imported from .SHP files). This object has also the Fill property. You can set the type and color of the interior Fill (independently on the MPolygon outline/border color) using the Properties window (Ctrl+1, the Pattern section). To completely suppress (switch off) the fill, use the POLYDISPLAY command and its "Edges" option, and regen your drawing. |
