AutoCAD Civil 3D General Discussion
Employee
8 Kudos
Post 21 of 28
Re: MPolygon select caushes crash/fatal error
06-30-2011 08:46 AM in reply to: eric_apostol
Hi Eric, and others:
Please install Civil 3D 2011 Update 2 (freshly released!) which should resolve this problem.
Himanshu Gohel
Autodesk, Inc
Active Contributor
0 Kudos
Post 22 of 28
06-30-2011 03:05 PM in reply to: hgohel
Hi Himanshu
Awesome!!!
MPolygon works fine now. So far I tested it to those drawings I have problem and they are not shutting down now. And also tried to create a new mpolygons, and they also work fine.
The only problem I notice so far, is editing. You can edit drag the other vertices but not the first vertice. Not sure if this is how the moply works. But hey, at least it is not shutting down which drive me crazy when you you are not aware that there is a mploygon on the drawing and haven't save the drawing (which result to rework and additional man hour).
Thank you so much for having this fix.
Cheers,
Eric
Member
0 Kudos
Post 23 of 28
01-17-2012 12:46 AM in reply to: hgohel
I have this problem too in Autocad map 2012.
Can someone tell me if there's a fix for this???
thanks!
*Expert Elite*
86 Kudos
Post 24 of 28
01-17-2012 01:10 AM in reply to: aflewelling
Autodesk is offering technical support in Spanish or in English only
Arturo Polanco
Employee
8 Kudos
Post 25 of 28
01-17-2012 07:15 AM in reply to: jo.moonen
@jo.moonen:
Please provide information about versions of products on your system - Civil and Map.  Do you also have SSA installed with Civil?
Do you have Civil 3D 2011 on the same machine?  Update 2 for C3D 2011 installed?
Himanshu Gohel
Autodesk, Inc
Member
0 Kudos
Post 26 of 28
01-17-2012 07:23 AM in reply to: hgohel
I have this error on the Autocad Map 3D 2012 edition.
I haven't installed the update 1 yet. I only saw this, when you told about it.
So I'll give this a try and let you know.
thanks!
Employee
8 Kudos
Post 27 of 28
01-18-2012 06:23 AM in reply to: jo.moonen
To understand the circumstances in which you are running into this crash, I really need to know the answers to the questions about which products you have on your system in addition to Map 3D 2012 (see my previous post).  Thanks.
Himanshu Gohel
Autodesk, Inc
Member
0 Kudos
Post 28 of 28
01-18-2012 06:38 AM in reply to: hgohel
okay, sorry, I didn't understand it.
I also have the following installed:
autocad map 3d 2011
Storm and sanitary analysis 2012
Industry model setup 2012
mapguide studio 2009 and 2010
thanks again!
Post to the Community
New Post
