Hi all,
I am having an issue In Civil 3D 2013, where I align a survey with old survey data. I would preferably setup over a bench mark or monument while doing my survey, but sometimes you have to work without one and adapt to the situation.
So, whenever I try to move my points and surface they default to an elevation anywhere from -2m to 4m, I reference back to my survey data and raise the points by the difference and all my points are matching the original survey data. As soon as I try to rebuild my surface (assuming that will rebuild it with the proper elevations) - My surface will create some holes and not update with the proper point elevations. My points will read the correct elevation ~625m-645m, but my surface will rebuild as a negative or very close to zero elevation.
I am stumped on this one, and wondering if anyone else has had this problem, or am I just missing something?
Thanks!
Are you moving the points with the move command? If so, you probably want to turn your OSNAPZ variable to 1 and set the ELV variable to 0. If you are snapping from a node to another node, you should check that the point styles Z-Display is set to 0. You might also try using the survey database and translating the points that way. Your surface should follow the points after they move and if there is no elevation shift, there shouldn't be any changes to the contours other than location.
What Kirk said. If that doesn't work, then post two dwg files: before the move and after the move.
Don Ireland
Engineering Design Technician
"Another way to move with out changing elevations, use the .xy filter and use 0 for the elevation when prompted. "
Yes. Absolutely. One can also simply draw a pline from origin to destination and snap to the pline for each part of the move.
Z must not change during the move command. All of the methods listed here will keep z constant accross the move.
John Mayo
Rick Jackson
Survey CAD Technician VI
